Anyone else driving a V-6?????
Old Feb 12, 2008 | 04:57 AM
1w@yfght's Avatar
Default Anyone else driving a V-6?????
I have a 1987 Acura Legend, I am putting a new motor in it and am stuck as to which one fits. I wanted to put the 94 NSX motor in it but as im finding out i might as well buy an old NSX for that kind of money. So im thinkin i should put a c27a from a 96 Accourd and all i would have to change is the ECU. Does anyone have any other suggestions on a faster motor that will bolt right to the 2.5 c27 tranny. Also i want to know a good light weight flywheel to add while the motor and tranny are apart. Thay all seem the same some are just sooooooooo expensive. Im new to hondas so i could use all the advise i can get.
Old Feb 12, 2008 | 07:40 AM
hatchling37's Avatar
Default Re: Anyone else driving a V-6????? (1w@yfght)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1w@yfght &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1987 Acura Legend
i should put a c27a from a 96 Accourd and all i would have to change is the ECU. </TD></TR></TABLE>
I'm sure you have way more work ahead of you than a simple ECU swap. You have all kinds of sensors not present in '87 that a '96 is probably riddled with. Wiring on that is gonna be a bitch. You have an OBD conversion to fight. Not to mention that the tranny probably won't bolt up without a conversion plate of some sort. Then there's the issue of mounts.
Sorry, chief. Don't take my word as gospel, because I'm not 100% sure that what I said is correct.
Old Feb 12, 2008 | 08:09 AM
jhammond_82's Avatar
Reject Papi
Default Re: Anyone else driving a V-6????? (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1w@yfght &raquo;</TD></TR><TR><TD CLASS="quote">sooooooooo expensive.</TD></TR></TABLE> yeah that would be.
go250mph
Acura TL, RL & ZDX
Sep 14, 2011 05:19 AM
1w@yfght
Classic Hondas
11
Apr 4, 2008 11:06 AM
fatboi07
31
Dec 26, 2006 01:10 PM
gezer
17
Jul 28, 2004 01:22 PM
