Any way to make LS/VTEC reliable?
Is there any way to make it a daily driver? Or semi daily driver? What are it's weak points? I have a B16A right now but I want more torque and building up the B16A is a little out of my budget. Any help is appreciated. Sorry for the noobie question.
there aren't really any "weak" points per-say, its more in the human-error side of things.
only thing i would keep an eye on is the VTEC Oil Feed line from the b18 block, if for some reason oil stops comin' outta that....
Do I need to upgrade the rods and pistons? Someone said that the rods have a tendency to snap after some time... What ECU do I have to have with the LS/Vtec?
Not that I would recommend this, but I've bonced mine off the rev limiter (8500) a few times at 8 pounds and no probs (yet). So like everyone says, "build it right."
Guest
Posts: n/a
Bamm!!! A properly built LS/VTEC
do the oil line right, keep an eye on oil pressure(ie. a guage), get a girdle in there, and some ARP rod and head bolts...you should be ok
if your concered about rods, get some Eagle rods or have yours shot peened
HTH
HTH
Once again....
LS/VTEC is reliable as daily driver as long as you do it right!
What's the point of doing LS/VTEC then? Don't people do LS/VTEC because LS block is a lot cheaper than a GSR block?
Jay Kim
[Modified by AllMotorMonster, 11:57 AM 12/5/2002]
Yea, buy a GSR block, and put a LS crank in it.
Jay Kim
Guest
Posts: n/a
Jay Kim
Jay Kim
