Any guess on my compression ratio?
You did a dynamic compression test. Static just takes cylinder volume , combustion volume, and gets a ratio between bdc volume and tdc volume.
A compression test like you do with a gauge is a dynamic test since it also takes the camshaft timing into consideration, which can change the overall compression.
Setup is
B18b block
Weisco 12.1 pistons
Je rods ...stock LS length
Stock B16 head
Cosmetic LSV headgasket
Bloxs Flat Racing Valves
Supertech Valve Springs
Stock LS crank
Blox Type C cams
B18b block
Weisco 12.1 pistons
Stock B16 head
Stock LS crank
Blox Type C cams
pootie.teng
Jun 2, 2005 10:32 PM
