Another radiator question.....
Old Dec 27, 2003 | 12:54 PM
sa21199's Avatar
Default Another radiator question.....
Ok, heres the deal, Im leaking coolant from my radiator. I dont know why I suppose there is a crack in it...I havent taken out the radiator to inspect it but I know its leaking from there cuz I can see it drip from the radiator. Second, I think my thermostat is done for because the fan doesn't turn on, I overheat, the heater doesn't work, and the lower radiator hose is cold. So my question is could the faulty thermostat cause all the problems or is it the lack of coolant in the radiator causing the overheat?
Old Dec 27, 2003 | 12:58 PM
quik1's Avatar
Default Re: Another radiator question..... (sa21199)
Lack of coolant will definitely cause this problem but just to make sure fill up your rad make sure there is no air left in it then see if you get heat but replace your rad asap.
inaety
Aug 4, 2011 04:15 PM
milkwasabadidea
Jan 8, 2011 10:22 AM
TsujenDB1
Jul 10, 2007 01:11 PM
Dat_One_Si
Jul 30, 2006 05:28 PM
94gsr_vtc
12
Jul 26, 2004 08:23 AM
