annoying clicking and no power windows
Old Jun 18, 2007 | 02:40 PM
doood's Avatar
been there done that
Default annoying clicking and no power windows
ok for about 3 months now i've had no working power windows which sucks because it's hot as hell down here now. they'll only work if i have the acc fuse in in the underhood fuse box, but at that point the car wont start. so the only way to open and close the windows and moonroof is to have the fuse in, turn the car on then open or close them, take the fuse out, then start the car. as you can tell doing this constantly is getting on my nerves. along with this there's an annoying *** clicking sound coming from the underdash fuse panel. i initially thought it was a bad power window relay, i took that out but the clicking continues. here's a clip:
the clicking starts getting faster when im driving and comes and goes. with the key in the ignition it will click for about 10 seconds, stop for 5 seconds, then start up again.
Old Jun 19, 2007 | 10:41 AM
doood's Avatar
Default Re: annoying clicking and no power windows (doood)
bump
Old Jun 19, 2007 | 01:15 PM
SD_Lurker's Avatar
HT White Ops
That is definetly a relay making that clicking sound. It sounds like an alarm relay to me. For instance if I unplug my amarm siren you can countinuously here that same clicking sound you are hearing.
Old Jun 19, 2007 | 06:42 PM
ALL IMPORT's Avatar
Default Re: annoying clicking and no power windows (SD_Lurker)
lol, i just had the same thing. took the damn alarm out & in the trahs it went. didnt do it all the time & it was hard to hear. problem fixed
Old Jun 19, 2007 | 07:41 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker &raquo;</TD></TR><TR><TD CLASS="quote">That is definetly a relay making that clicking sound. It sounds like an alarm relay to me. For instance if I unplug my amarm siren you can countinuously here that same clicking sound you are hearing.</TD></TR></TABLE>
yea there's wiring for the alarm right next to the fuse box. it's a real bitch to get to but i'll check it out tomorrow. if it does turn out to be an alarm relay can i just rip it all out?
the thing is this only started happening after i replaced the battery. it ran fine before then.
Old Jun 20, 2007 | 12:16 PM
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">yea there's wiring for the alarm right next to the fuse box. it's a real bitch to get to but i'll check it out tomorrow. if it does turn out to be an alarm relay can i just rip it all out?
the thing is this only started happening after i replaced the battery. it ran fine before then. </TD></TR></TABLE>
thats exactly what it is then. When you replaced the battery it reset the alarm. Do you have the key to the alarm? if not there should be a toggle switch to disable the alarm. I am 200% certain that its your alarm
Old Jun 20, 2007 | 06:06 PM
doood's Avatar
nope i dont have a remote for it. it was installed by the previous owner and i've never even used it.
Old Jun 20, 2007 | 10:03 PM
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">nope i dont have a remote for it. it was installed by the previous owner and i've never even used it. </TD></TR></TABLE>
I am 100% positive that is what the ticking sound is coming from. Its the alarm!
Old Jun 25, 2007 | 05:20 PM
doood's Avatar
success!!
so i got under there today and took a closer look. first pulled out the fuses for the alarm and that seemed to do the trick. the windows and dome light are working again. after driving for a few minutes i noticed the clicking was still going. so i got back under there and found the box the alarm, it was in a real tight spot but i managed to grab the connectors to it and unplugged it. no more clicking!
thanks for the help
Old Jun 25, 2007 | 06:13 PM
NJIN BUILDR's Avatar
My friend spends at least three days a week removing aftermarket alarms.His first question to any problem is does it have an alarm.He has boxes of alarms and wiring.It's almost like boxes of trophies.There must be two thousand scotch-locks in those boxes.
Old Jun 25, 2007 | 07:27 PM
doood's Avatar
it's just nice having working windows again
thekingofvtec
Jun 12, 2018 02:29 PM
eagleclawracing
Nov 12, 2012 10:52 AM
doood
Aug 30, 2007 10:03 AM
doood
Jun 19, 2007 10:42 AM
keepitngga1
Nov 28, 2006 01:49 PM
