alternator not charging?
Old Mar 24, 2005 | 12:46 PM
PTR1's Avatar
Default alternator not charging?
I was wondering if anyone run into this problem before. Hondata s200 w boost. b18c drag turbo kit. Normal driving is fine but when i get on it, occasionally the battery voltage drops to 12.1 volts and the car lean out and starts to sputter real bad. Changed out new alternator, battery, etc. nothing seems to work. please help!!
Old Mar 24, 2005 | 02:28 PM
skunked's Avatar
Default Re: alternator not charging? (VIMPORT.COM)
check your grounds. Are you sure your fuel pump isn't taking a $hit?
Old Mar 24, 2005 | 09:01 PM
PrettyLude's Avatar
you don't have one of those aem pulley's on it do you?
Old Mar 25, 2005 | 07:19 AM
skunked's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">you don't have one of those aem pulley's on it do you?</TD></TR></TABLE>
Have the aem pulleys caused this before? Interesting point.
Old Mar 25, 2005 | 07:39 AM
PrettyLude's Avatar
on my lude, it was not producing enough current at idle, therefore, draining my battery dead, and i didn't even have alot of electronics either
Old Mar 25, 2005 | 08:06 AM
skunked's Avatar
You learn something new every day. I have never ran the pulleys including lightweight crank pulleys so I wouldn't know.
SPOOLINmatt
Jun 23, 2010 02:18 AM
0ni
Jun 26, 2005 02:01 PM
H22aAccord
Dec 6, 2004 06:40 PM
el402
May 17, 2002 06:55 AM
