ALL-MOTOR questions....
Old Nov 13, 2001 | 08:36 PM
ultraspeed2nr619's Avatar
New User
Default ALL-MOTOR questions....
I have a B20VTEC motor pretty much assembled already.. i have just about EVERYTHING (cams pistons etc...)for it.. hahahaa.. i wanted to get rods BUT i held off for a few easons...
1. most stock rods are lighter than the forged versions....
2. i wanted to get a custom length to adjust and better the r/s ratio...
SOOOO i need to find a place to get some NICE LIGHT all-motor rods and stuff from... **** well anything lighter would be nice.. lighter pins would be REALLY nice.. my fuggin wrist pins are heavier than my damn pistons.. theyre the new JE B20 w/B16A head... 10.5:1 Cr... MILLED HEAD 30...to bring the CR up a bit... so guys..let me know...thanks
Old Nov 14, 2001 | 04:48 AM
BoM's Avatar
BoM
Default Re: ALL-MOTOR questions.... (ultraspeed2nr619)
eagle rods
and if your going N/A should've brought your compression
up more to like 11.5 or 12.0
Old Nov 14, 2001 | 06:30 AM
rainforest's Avatar
Default Re: ALL-MOTOR questions.... (Spade)
you might want to get longer rods it will increse your r/s endyn will make custom rods,but you have to take into considertion that you will also have higer comprresion on your pistons when you do this, so remeber to tell larry at endyn what you are doing. I say get it done at endyn busta.
Old Nov 14, 2001 | 06:39 AM
Spade's Avatar
Default Re: ALL-MOTOR questions.... (rainforest)
What is the difference between the LS crank and the B16 Crank? Any? Or does the B16 just have shorter rods?
Old Nov 14, 2001 | 08:46 AM
rainforest's Avatar
b16a 77mm stroke ls 89mm stroke and the b16a has oil squirters.and yes the b16a has 133mm rods and the ls has 137mm rods.
Old Nov 14, 2001 | 09:14 AM
Spade's Avatar
good my mind was right.....shorter rods on the b16.....
Old Nov 14, 2001 | 01:00 PM
mr2's Avatar
mr2
good luck with your all motor setup, sounds good
Old Nov 15, 2001 | 04:00 PM
New User
thanks guys.. umm but i kinda knew that much.. reason im asking you all is because i was hoping some of you honda prodigy's out there would know some numbers,... thats whut i need.. so i can order the pistons.. i guess i could go to T.O.O. but i was juss gonna chek here first.. thanks guys...
PnkRokCountryboy
17
Nov 20, 2005 04:08 PM
eg6madness
Mar 7, 2003 01:58 AM
tinkerbell
Oct 24, 2002 09:11 AM
