are all b series piston rings the same?
Old Feb 26, 2003 | 04:43 PM
SSBP DC2's Avatar
Default are all b series piston rings the same?
i have a set of pct pistons, i was wondering if all b series piston rings are the same. i checked a couple of dealers and they have different part #'s and different prices for different b series motor (for the rings that is).
TIA
Old Feb 27, 2003 | 11:10 PM
SSBP DC2's Avatar
Default Re: are all b series piston rings the same? (SSPB DC2)
ttt
Old Feb 27, 2003 | 11:13 PM
Spartanic's Avatar
Actually they may be differnt since not all the B series engine put out the same compression. The type R engines may have better piston rings(more expensive) since the compression they make is higher and will put more pressure on the rings.
Old Feb 27, 2003 | 11:20 PM
Westrock2000's Avatar
Default Re: are all b series piston rings the same? (Spartanic)
ya and b16 rings definently wont work in a B20
Old Feb 28, 2003 | 11:25 PM
SSBP DC2's Avatar
Default Re: are all b series piston rings the same? (Westrock2000)
i should have asked all b series with the same bore, which is i what i meant. my main concern is would a set of rings from a b16a (Si motor) could be used in a b16b (ctr) pistons. they should right? same size bore even same displacement, sort of.
Old Feb 28, 2003 | 11:55 PM
B18Ccivic's Avatar
My knowledge of all b series is somewhat limited but I just got done installing a new set of J&E rings in my b18C. infact, I just now walked into the house after starting it for the first time. Biggest job I've ever tackled, I was totally scared to start it but it went ok. anyway back to your question I originally bought factory rings but they were too small since the previous owner had a .020 overbore done and I didn't know it. So I had to order the J&E's. The factory ones would have worked perfectly, they were just .020 too short.
turbociv910
Engine Machining & Assembly
Sep 2, 2017 06:27 AM
egboy94
Apr 22, 2010 05:40 AM
egboy94
Apr 22, 2010 05:39 AM
I8ayellowcrayon
Oct 26, 2006 09:20 PM
13secLSVTEC
Jul 8, 2001 07:10 PM
