are all 92-95 civic VSS interchangable. Speedoo problem
I have 92 civic whos speedoo works than doesn't work. At the same time my odometer dies and comes back on with the speedoo. I'm thinking it's probably the VSS that is bad.
Now will any 92-95 speed sensor work? Does it matter if it's off auto or manual tranny. I found one thats off a 5spd and mine is 5spd but I'm just wondering if they are all the same.
Thanks
neven
Thanks
neven
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">clean the connector first, this will solve 99% of all VSS issues on 92-95 Civics.</TD></TR></TABLE>
What kind of solvent should one use? Or which solvents should one stay away from?
I have the same problem, and the problem remains even after my swap. I think I'm in the 1% of people with wiring/grounding problems which affect the cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jazzman »</TD></TR><TR><TD CLASS="quote">I have the same problem, and the problem remains even after my swap. I think I'm in the 1% of people with wiring/grounding problems which affect the cluster.</TD></TR></TABLE>
So if I upgraded to a heavier gauge grounding setup it should correct my jumping Speed sensor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran13 »</TD></TR><TR><TD CLASS="quote">
So if I upgraded to a heavier gauge grounding setup it should correct my jumping Speed sensor?</TD></TR></TABLE>
no. fix the problem first.
b18c4door
Oct 8, 2007 08:41 AM
