Air/Fuel Ratio to V-AFC Settings
Old Oct 9, 2002 | 11:23 AM
satan_srv's Avatar
Default Air/Fuel Ratio to V-AFC Settings
From reading an Air/Fuel graph from a wideband O2, can you safely determine some V-AFC adjustments?
V-AFC % are a function of the injector pulse at a given rpms right? Or do I need another piece of information like the duty cycle at a given rpms to accomplish this? I think that's the only missing link here...since I know the injectors are 370cc
Any thoughts? Thanks in advance
Old Oct 10, 2002 | 09:08 AM
satan_srv's Avatar
Default Re: Air/Fuel Ratio to V-AFC Settings (satan_srv)
anybody?
Old Oct 10, 2002 | 09:12 AM
lightning's Avatar
Needs to be done "real time". Problem is that atmospheric conditions will change and you might be working in different load cells in the ecu.
Old Oct 10, 2002 | 09:52 AM
satan_srv's Avatar
Default Re: Air/Fuel Ratio to V-AFC Settings (lightning)
Yeah I was thinking that without the dyno after to see the results you can't directly determine what the outcome or inputs should be
Old Oct 10, 2002 | 12:06 PM
shadowdawn's Avatar
Well if you don't live in the mountains and are changing altitudes alot like me, when I went to the dyno and tuned on a wideband my ratio was at a nice 12.0-12.4 while in boost.... seemed to turn out well.
If you wanna see my exact settings goto my website in the sig.
bird00420
Jul 29, 2008 01:07 PM
rdssk8rcs1
Jan 29, 2006 07:40 PM
hialeahzbg
Aug 25, 2005 11:50 AM
gsrx
Nov 24, 2004 02:12 PM
kHoA DoGG
Oct 9, 2002 08:37 AM
