Air Fuel Ratio
Old Jan 20, 2004 | 07:24 AM
sleepin91teg's Avatar
Default Air Fuel Ratio
What all is involved in installing an AutoMeter Air Fuel Guage? What skill level will this take?
Old Jan 20, 2004 | 07:56 AM
Kataku2K3's Avatar
Default Re: Air Fuel Ratio (sleepin91teg)
Nothing special at all, knowing how to find a ACC 12VDC+ from the fuse box, a nice ground, and where your oxygen sensor is... Besides that it's pretty straight forward, if you know how to read ECU pinouts that definately helps because it allows you to tap your A/F meters signal line inside the car instead of running a wire out to the engine bay... Either way you're on the same line, I'm just extremely picky about wiring, etc... Good Luck
97turboteg
May 5, 2006 10:10 AM
hb_usc
Apr 18, 2006 05:00 PM
1 slo ex
Nov 20, 2002 11:38 AM
