Air/Fuel Problems with stock motor
Old Jan 10, 2009 | 08:17 AM
chris3385's Avatar
Default Air/Fuel Problems with stock motor
Well everything was looking up, I had my b18c1 ready to put all my turbo gear on but replaced the throttle body gasket because I believe it was leaking a tiny bit. Anyhow I had my 550s installed, 3 bar map and Phearable ecu with my basemap. I'd start it up and the air/fuel ratio would be around 13.2 at idle and get richer as the throttle increased which i thought is how it should be.
Anyhow I replaced my throttle body gasket and put everything back how it was and now I have an air fuel ratio of 15.0 at idle with the same setup as I had before and if you increase the throttle it goes up as high as 15.4
I put my stock ecu back in, stock map and stock injectors and again it was around 15.0 and went up as high as 15.5 with a blip of the throttle. And got a code 20 ELD code which I don't believe has anything to do with this.
It idles perfect but the only thing I can think of is a vacuum leak around the throttle body... What does everyone else think?
Thanks,
Chris
Turb0wned
38
Jun 13, 2010 09:50 AM
ekhatch66
Engine Management and Tuning
Aug 19, 2009 09:14 AM
platinum00
Dec 12, 2006 01:13 PM
iBrandon
Feb 27, 2006 07:35 PM
Nikos
Sep 4, 2002 11:15 AM
