Air fuel mixture with Autometer gauge
Old Aug 10, 2006 | 09:07 AM
Quade's Avatar
Default Air fuel mixture with Autometer gauge
How many of you guys are using them? Do you get a range of about 4 to 5 lights being lit as the display goes from left to right? If you are then something is not right and we need to work together to fix this. It's a common problem with hondas and I see other hondas here with the same problem and I'm convinced it affects performance. The computer is basically seeing this (blurr) change in readings and trying to compensate accordingly. I already change my O2 sensor same problem. I also change my guage thinking it was bad. Is this happening to any of you guys? When I first installed the guage it lit up one led at a time and the car ran perfect
Now even at full throttle I get about 4-5 leds on in the rich area. We really need to solve this.
Old Aug 10, 2006 | 09:34 AM
Relic1's Avatar
I'd guess you have a ground or noise problem.
the O2 oscillates at cruising from ~.3-.75 volts. This can be quick enough to be a blur.
But if you're getting a blur at WOT you have a problem.
either electrical or tuning.
Quade
Aug 10, 2006 08:55 AM
2khb
Apr 24, 2005 07:55 PM
jay99EK
Dec 24, 2002 04:56 PM
Meth
Jan 8, 2002 09:05 AM
