--Air Cond. woes, please help--
Old Aug 22, 2004 | 06:30 PM
Arsenal's Avatar
Default --Air Cond. woes, please help--
When I go to turn the Air con on, sometimes it stays on and others it doesn't.
It will kick in then turn off again though
Has anyone ever had this problem or does anyone know what the problem is?
I ordered the fan switch by the climate control as a few people said thats what it could be.
When I slide the dial to 1, 2 or 3 the blower motor works, but the condensor fan and compressor does not. Its either both on or nothing, just the blower motor.
Also does anyone know where the Thermo Switch is or the AC Pressure Switch?
They both have the same colour wires going in and out, tested them but both are on resistors.
Thankyou.
Old Aug 22, 2004 | 06:38 PM
eda6's Avatar
Default Re: --Air Cond. woes, please help-- (Arsenal)
check the refrigerant charge. if you have a leak it's going off on low pressure. if the condenser is dirty it's going off on hi-pressure. do you see signs of oil on piping? i dunno where the ac pressure and thermo switches are? i don't have ac in the hatch.
Old Aug 22, 2004 | 06:41 PM
Arsenal's Avatar
Default Re: --Air Cond. woes, please help-- (eda6 hb)
The pressure is normal, not high or low, and no oil around piping.
Old Aug 22, 2004 | 06:56 PM
eda6's Avatar
what's your pressure? once you find the dual pressure switch pull off the connector and jumper it out. if the comp/cond fan energize the pressure switch is bad. what car are we dealing with?
Old Aug 23, 2004 | 06:41 AM
Arsenal's Avatar
Its a 95 Civic CX, is the dual pressure switch underneath the 2 relays for the compressor and condensor fan?
Old Aug 23, 2004 | 06:02 PM
Arsenal's Avatar
anyone else?
Old Aug 23, 2004 | 07:09 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">Its a 95 Civic CX, is the dual pressure switch underneath the 2 relays for the compressor and condensor fan?</TD></TR></TABLE>
from the right side of vehicle, follow the bottom refrigerant line until you see the dual presssure switch. it's in the vicinity of the battery.
Old Aug 24, 2004 | 09:10 AM
Arsenal's Avatar
Thanks, I ll take a look at it.
Old Aug 25, 2004 | 12:22 PM
Arsenal's Avatar
Okay, replaced the switch inside the climate control part, no change.
However,
I switched the 2 relays around and they are fine,
So, got a test light, attached it to the chassis for a ground and went searching.
Under the 2 relays there is a plug which has 2 wires going into, a blue/red and a yellow, just above the compressor. Now when I turn the AC on, if i put the tester into the blue wire slot the compressor kicks in, but the fan does not, so if this is the case, can I just wire a switch to the condensor fan and this blue/red wire, and whenever I want the AC on just flick the 2 switches?
DMorrison67
Aug 28, 2018 09:17 AM
soundquest
Honda Civic (2006 - 2015)
May 23, 2018 12:15 AM
crvivar
Honda CR-V & Element
Jun 3, 2015 12:09 AM
jdadams12
Jul 13, 2006 08:05 AM
freddy_hung
11
Sep 21, 2003 07:32 AM
