AHHH, valve seal replacement help....again.
Old Mar 27, 2004 | 09:30 AM
Witty's Avatar
Default AHHH, valve seal replacement help....again.
When I try to compress the cycinder to keep the valves from falling in the air just leaks out. When I do a normal compression test with the head together I don't have this problem. Anyone have any ideas on what I am doing wrong?
Old Mar 27, 2004 | 10:13 AM
mmuller's Avatar
Mad Scientist
Default Re: AHHH, valve seal replacement help....again. (Witty)
are you putting the cyl. at tdc? its always gonna leak a little, you need a constant supply of air.
You can also put strings in the cyl. to keep the valves from dropping
Old Mar 27, 2004 | 10:34 AM
Witty's Avatar
Yes, cylinder is at TDC. What PSI should I use on my tank? I didn't know I needed a constant supply. I though I could just blow it in and it would stay.
Old Mar 27, 2004 | 10:41 AM
simple4012's Avatar
New User
i dont know how you are gonnado thatwith the head on the car. valve seals are a bitch period
Old Mar 27, 2004 | 11:02 AM
Witty's Avatar
I got it. Nevermind. Thanks though.
ungcobob
Apr 25, 2014 06:59 PM
Chuonthis069
Oct 22, 2012 08:15 PM
92integraVTECgsr
10
Oct 17, 2009 11:13 PM
MisterB
Jun 4, 2003 09:31 PM
98Psi ITR
Dec 5, 2001 10:59 AM
