Aftermarket Crank
This is a pretty hypothetical question but I was wondering if anyone knew where i could get an aftermarket crank for a D16A6.
The reason Im asking is because I currently have a mini-me with hi-comp pistons (about 14:1 comp), and i was considering going Turbo. Just to kill anything, and im guessing ill want a stronger Crankshaft.
Am i wrong? or if im not, any suggestions?
Wow how did you get that high of compression? What octane gas do you use? I searched and found that there are no cranks for d series. Your oe crank will be fine, you can knife edge it for better performance and get it micropolished. And you cannot boost that high of compression bc it will blow your block to pieces. You should get vitara pistons if your planning on going boost imo. Good luck man
Well its actually like 13.5:1, but i put PM7 High Comp pistons in it when i rebuilt my engine. They added alot of power!
I put 91 in it, cuz i dont wanna blow the bank everytime i fill up, and it does fine, im using it as a daily driver/ kick everyones *** on the street car
Like i said this is all purely hypothetical, and i was thinking it would probably shatter my block but itd be sick! Haha
right now im guessing it has 180 whp :D
oo and its the Y8 instead of the typical Z6
Jason Helton
Mar 12, 2018 06:34 PM
