Aftermarket Cam and Emissions CA?
Old Apr 25, 2003 | 10:25 AM
struppi's Avatar
Default Aftermarket Cam and Emissions CA?
Will an aftermarket cam effect emissions on a d16z6? Does it depend on the type of cam, I was thinking Zex 59300? I live in So. Cal. and was just wondering if this makes it harder to pass smog check.
Thanks!
Old Apr 25, 2003 | 12:07 PM
joe_bocc's Avatar
Default Re: Aftermarket Cam and Emissions CA? (riversideguy)
Changing your cam could definitly effect your emissions. Since your cam allows more air in the engine you put more fuel in the engine which creates higher emissions.
Old Apr 25, 2003 | 12:21 PM
kb58's Avatar
Banned
It depends on the cam specs, specifically how much overlap there is. That keeps the intake and exhaust valve open at the same time and lets unburned fuel into the exhaust. As for whether it'll effect your ability to pass inspection will depend on that. Technically unless it has an EO number, it's illegal. I wouldn't volunteer the fact that you have a cam (any cam) to the inspector...
Oct 23, 2009 01:40 PM
integrajake
May 16, 2007 02:51 PM
Daniel
Jul 9, 2003 05:53 PM
