After cam install car won't start.. any pointers?
Old Feb 15, 2003 | 11:36 PM
95 Gizzer
Guest
Posts: n/a
Default After cam install car won't start.. any pointers?
Hey, I put in type r cams into my car today and now the car won't start.. I'm gonna tear it all apart and do it again tommorrow, but I was just wondering if you guys had any pointers for putting them in the next time around? I'm almost 100% positive it was at tdc so.. not quite sure what I did wrong, but if that were the case wouldn't it still start, but just act really funny?
Thanks guys
[Modified by Jay Hovah, 1:02 AM 2/16/2003]
Old Feb 16, 2003 | 12:11 AM
sgT's Avatar
sgT
Default Re: After cam install car won't start.. any pointers? (Jay Hovah)
did you do a valve adjustment?
Old Feb 16, 2003 | 12:12 AM
95 Gizzer
Guest
Posts: n/a
Default Re: After cam install car won't start.. any pointers? (sgT)
no...is that necessary to make it run?
ULTRA911's Avatar
will it still crank? even if you're off by 1mm or 2, it'll still turn over. spark plugs wires in the proper firing order?
Old Feb 16, 2003 | 12:38 AM
95 Gizzer
Guest
Posts: n/a
Default Re: After cam install car won't start.. any pointers? (ULTRA911)
I checked the spark plugs like 5 times because I figured that might be the problem. But they all seem to be fine. When I put the key in the ignition (and turn it) it sounds like things are moving and the exhaust makes this tiny little noise, but it just doesn't start. Btw- I know it's hard to figure out a problem like this when you can't see it, so thanks for helping out I appreciate it.
[Modified by Jay Hovah, 1:39 AM 2/16/2003]
Old Feb 16, 2003 | 03:47 AM
xsolidcellx's Avatar
sounds like timig is off, its prob slipping wen u are tightening up the tensioner juss try it again and c wut happens
Old Feb 16, 2003 | 04:34 AM
Chiovnidca's Avatar
Maybe.
Old Feb 16, 2003 | 07:17 AM
black-hatch's Avatar
Default Re: After cam install car won't start.. any pointers? (Chiovnidca)
check ur ground from valve cover to chasis and check ur battery and cables
Old Feb 16, 2003 | 10:46 AM
mts20k97's Avatar
Default Re: After cam install car won't start.. any pointers? (black-hatch)
i had the same problem after i put my cams in. turns out i put the distributor on 180 out of time . you should do a valve adjustment before you start it.
ant13
Aug 20, 2011 09:44 AM
EGandDArida
Aug 24, 2009 02:34 PM
LeeTrucker
Mar 28, 2009 10:59 AM
yOnKiNaToR
Mar 26, 2009 05:19 PM
bonestock92si
38
Aug 30, 2004 10:02 PM
