afLs/vtec price
depends....if you want it done right then it will cost you about 5-7k depending on where you go. If you want micky mouse **** done then it will cost you roughly about 1-2k
let's see I had ericks racing in torrance build my bottom end all in all it cost me around $2000 which included rods ITR pistons boring and balancing of everything blah blah blah and I payed $500 for the short block and some other odds and ends.
then I had portflow do the cylinder head for around $1300 portflow retainers, spring, ITR intake valves, port and polish milling...blah blah blah cams cost me $600 CTR's
Oh I also knifed the crank which cost me $250 and I had a custom flywheel made which was another $250 and then I had a custom clutch made for another $250 all done by RPMservice in Lancaster.
I then purchased RC 270cc for $200 need to still get a header $300 trans $350 axels $200 shiftlinkage $200 my mount kit $350 ECU $200 dyno time and tuning $400 cam gears $100 other odds and ends timing belt brackets plug wires plugs fluids blah blah blah $400 - $500
Sick of typing all this **** but I think you'll get the point. Whip out the calculator and you see how much damage I did.
ITR.#1446
Northeast (Sales)
Feb 15, 2009 03:08 PM
nxvictim
Apr 4, 2008 11:59 AM
