AFC reading O2 voltage WITHOUT blue wire mod.......
Old Aug 10, 2003 | 04:18 PM
Bailhatch's Avatar
Default AFC reading O2 voltage WITHOUT blue wire mod.......
problem---you can only see your O2 voltage under the sensor check menu you can not directly compare to rpm,correction etc.
idea for a solution----Would it be possible to use the Knock sensor input on the SAFC 2 for the O2 and then you could record or at least compare #s on the same screen. Is the voltage range the same? Is it even a voltage output? I believe KS reads a voltage under the sensor check, that is why I think this might work
I was just driving looking at the screen with the rpm and tps bar graphs and all the other stuff and noticed the knock section reads 0 because I don't have it hooked up. Would this work? Could you use it for anything else? Thanks for any input
Old Aug 10, 2003 | 05:14 PM
Blaze45's Avatar
Brrraaaap!
Default Re: AFC reading O2 voltage WITHOUT blue wire mod....... (Bailhatch)
I would try it and see... Worth a shot...
Blaze
Old Aug 10, 2003 | 05:35 PM
NonovUrbizniz's Avatar
Loved
I don't think so...
Use a voltmeter to be sure... but I'm pretty sure the o2 operates at varied ranges of voltage to indicate different mixtures...
where as the knock sensor just sends a single "trigger" voltage to alert of a single knock.
Old Aug 10, 2003 | 05:37 PM
mmuller's Avatar
Mad Scientist
Default Re: AFC reading O2 voltage WITHOUT blue wire mod....... (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">I don't think so...
where as the knock sensor just sends a single "trigger" voltage to alert of a single knock.</TD></TR></TABLE>
Old Aug 10, 2003 | 06:50 PM
Bailhatch's Avatar
So the knock signal would just be short bursts of the same voltage? I wonder how the SAFC II processes and displays the info. Maybe the number the AFC gives is a knock/time kinda thing. like 3 "triggers" in one second, or something like that. Anyone know for sure?
Dioxine
16
Oct 4, 2016 02:45 PM
minituner
Mar 26, 2016 04:16 PM
BLUE EH3
May 16, 2005 07:24 PM
LsTurbo91
Oct 8, 2001 09:20 PM
