AEM EMS VS. OBD1 conversion???
Old Feb 6, 2004 | 09:01 PM
B16CRXT's Avatar
Default AEM EMS VS. OBD1 conversion???
My question: If I get the AEM EMS would I need to go through all that BS with the 4 wire O2 and the obd1 dizzy? If I want to do hondata or just fix this 2 O2 crap i have to convert to obd1. (BTW: Im an OBD0 Pr3 B16.) I assume that if I get the AEM that will gix all the issues that the PR3 has becasue it directly replaces the entire ECU. Am I right? Would it be more cost effective to go this method instead of doing the obd1 p28 swap then hondata?
Thanks for your help and opinions guys!
Old Feb 7, 2004 | 10:02 PM
B16CRXT's Avatar
Default Re: AEM EMS VS. OBD1 conversion??? (B16CRXT)
bump
Old Feb 9, 2004 | 07:41 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">My question: If I get the AEM EMS would I need to go through all that BS with the 4 wire O2 and the obd1 dizzy? If I want to do hondata or just fix this 2 O2 crap i have to convert to obd1. (BTW: Im an OBD0 Pr3 B16.) I assume that if I get the AEM that will gix all the issues that the PR3 has becasue it directly replaces the entire ECU. Am I right? Would it be more cost effective to go this method instead of doing the obd1 p28 swap then hondata?
Thanks for your help and opinions guys! </TD></TR></TABLE>
You would not need to upgrade to the OBD1 distributor if you decide to stay with the AEM. You can change the trigger wheel sequence to match that of the OBD0 distributor. The 4 wire O2 sensor though, I am not 100% sure. If you need a harness, check out my website in my Sig. My tech service and customer support has exceeded others time and time again. I will let you know what I find out on the 4 wire O2 sensor.
On the Hondata setup, you will need the the 4 wire O2 sensor, OBD1 ecu and the OBD1 distributor. I have OBD1 P28 ecus in stock as well as the OBD0-1 harness
Jason
http://www.JKOBDConversionharness.com
Old Feb 14, 2004 | 10:55 PM
B16CRXT's Avatar
Default Re: AEM EMS VS. OBD1 conversion??? (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">
Jason
http://www.JKOBDConversionharness.com</TD></TR></TABLE>
Find anything yet? Anyone else got some info to add to this? Thanks!
darrenVT
Engine Management and Tuning
18
Sep 30, 2008 09:18 AM
1PT-SICK
Nov 16, 2006 04:30 AM
sleepin91teg
Jun 30, 2005 08:20 PM
EFing8
11
Dec 15, 2002 09:08 AM
