AEM 3.5 bar map sonsor and Zeitronix using in conjunction
I am using a AEM EMS and also use the Zeitronix for wideband monitoring and was wondering since I got a AEM 3.5 map sensor can I use it also for the Zeitronix unit for boost logging?
I've had no problems with the AEM and the Zeitronix working together just didn't want to mess anything up.
TIA
TIA
but can I split tap into the wires going to the EMS from the map sensor and feed the Zeitronix box.
I guess I'm asking will tapping into the signal wires have an effect on the signal being read by EMS? or will they read the same?
Im sorry guys for bring this threar from the dead, but i would like to know if this will work for shure!?
I found this FAQ (on DSM forum) wich explains which wire goes where but only problem i have i have 3 wires on AMS map black, white and red!
slowteg550
May 4, 2006 07:26 PM
mister2racer
May 10, 2004 07:56 AM
