Adjusting idle on BBK Throttle Body
Old Feb 11, 2004 | 03:40 PM
RPRacing's Avatar
Default Adjusting idle on BBK Throttle Body
OK, i recently installed a BBK 70mm TB on my Teg. at first, my idle was really high. the guy who helped me with the head swap lowered it somehow (i have my boy telling him to call me tomorrow). Now, my idle is low. like 300rpm low. and most of the time when i brake and come to a stop, my car dies out on me. I'm really wearing out the starter here. I have looked for the idle set screw on the TB and found nothing. does anyone know where it might be???
also i just talked to my boy and he said it should be under the throttle dial itself. i looked all around there and there is a small cube with a hole in it going vertical, looks like it has threads in it. could the screw have been here???
any input is needed. thank you
Old Feb 11, 2004 | 07:29 PM
Too_Smooth's Avatar
Default Re: Adjusting idle on BBK Throttle Body (sucka306)
Ok, look where the throttle cable is on the TB. Now just feel or look below that. You should see the screw to adjust the idle. Hope that helps man....good luck.
Damn just read your entire post...you're looking in the correct spot. Seems like the screw is missing...should be an easy fix.
Old Feb 11, 2004 | 07:36 PM
RPRacing's Avatar
yeah, i just looked at some pics when i first got it, when it was still in my room and i see the screw there. now i look in the same place and its gone. anyone know the measurements of that screw??? or should i just contact BBK for a new one???
Old Feb 11, 2004 | 07:37 PM
RPRacing's Avatar
Screw (on left)
No screw
Old Feb 11, 2004 | 07:43 PM
Too_Smooth's Avatar
Just try some screws till you find one that works...easiest thing I know to do.
Old Feb 11, 2004 | 07:50 PM
RPRacing's Avatar
i'd rather not take the chance of stripping it out. i know that these aftermarket parts have tendencies to do that
new_climber
Dec 6, 2009 05:44 AM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
black bandit
Jan 14, 2008 04:26 AM
TheHatchHog
May 15, 2003 06:16 AM
bleebdat
Jan 7, 2003 10:52 AM
