adding a relay, wiring help please.
I have a bosch single pole relay and i need it to install my foglights legally so that they turn off when i put the high beams on...so basically i need help to decide which wire goes to where...thanks
30-blue
85-white
86-black
87-yellow
87a-red
im taking a guess, but i think 86/black would be body ground, and red would be power to the battery...any help is appreciated...
30-blue
85-white
86-black
87-yellow
87a-red
I'd recommend that you go to "the12volt.com" for any information that you may want on relays. If you look over their site, you will find the answer and also a whole bunch of other ideas.
Wes
Wes
so:
30/blue=power from foglight switch
85/white=power from battery
86/black= ground to body
87/yellow=foglight power
87a/red= high beam power wire
is that correct?
is that correct?
pnwjdm
17
Sep 29, 2013 01:11 PM
j4s0n1337
May 6, 2011 12:00 PM
