actual difference between walbro 255, HP and normal?
Old Jul 27, 2004 | 06:36 PM
mmmVTEC's Avatar
Default actual difference between walbro 255, HP and normal?
what is the difference exactly? specific situation here is going boost, using an AEM FPR and dsm 450s with a VAFC. so...the fpr just makes sure that the fuel being delivered to the injectors isn't at too high of a pressure. so is there a benefit to the high pressure fuel pump or not? is it kind of a range situation, where the HP version is just build sturdier so it can handle higher pressures, or does it deliver it at a higher pressure all the time...?
and don't just say higher pressure is better, because you'd be wrong.
http://www.hondata.com/techfuelpump.html
Old Jul 27, 2004 | 07:24 PM
mmmVTEC's Avatar
anybody?
Old Jul 28, 2004 | 10:56 PM
mmmVTEC's Avatar
bump.
Old Jul 29, 2004 | 09:50 PM
eda6's Avatar
Default Re: actual difference between walbro 255, HP and normal? (mmmVTEC)
I switched to a walbro because my pump was 16 years old.
Considered it preventative maintenance.
I heard honda fuel pumps were good to 50 psi.
Hondata says 75 psi. Thats new to me.
You will be running higher pressures all the time.
I installed this on an 88 dx hatch w/b16.
I saw 8 lb increase in pressure.
I've heard the walbro is good until about 70 psi.
i'd say the benefit is going above 50 psi safely.
Do have a fuel pressure gage? If you don't get one.
Old Jul 30, 2004 | 12:28 AM
mmmVTEC's Avatar
sorry if i was unclear, i mean what's the difference between a walbro high pressure fuel pump and a walbro fuel pump. maybe if i put that in the title i'd actually get some responses...
HarfordCTR
May 27, 2009 11:50 AM
1SlowSi
Nov 9, 2004 01:13 AM
silverb18
May 29, 2004 12:20 PM
Familycarfromhell
Feb 11, 2003 06:01 AM
