ACG fuse? What does ACG mean?
Old Feb 29, 2004 | 10:25 AM
asmallsol's Avatar
Default ACG fuse? What does ACG mean?
What exactly does ACG mean. Yeserday I accidently pulled it out, when I was reaching for the fuse puller, then put it in the wrong space. I tried to start my car, and it wouldn't start. I was freaking out. Checked for spark, no spark, checked for fuel, no fuel. So I checked the ECU fuse, it was all good. Then I checked the Ecu, all the connections looked fine. Checked my grounds, they were all good. I couldn't figure it out. Then I started to retrace my footsteps, and noticed that in 15amp ACG (S) slot on my fuse map was empty. Put a 15amp fuse in there, and it started right up.
Now my question is, what exactly is ACG. What does it stand for? I know what happens when it goes out, but I would like to know a little more. I did a search and found 4 posts, 3 archived and one present. I read through each one, and no one had a clear explination.
Old Feb 29, 2004 | 01:47 PM
asmallsol's Avatar
Default Re: ACG fuse? What does ACG mean? (asmallsol)
bump
Old Dec 10, 2004 | 01:35 PM
McNizzle's Avatar
ever shed any light on this? im having a problem where my ACG fuse keeps blowing
Modified by Chris M at 10:40 PM 12/10/2004
Old Apr 3, 2005 | 01:17 PM
BigDaddyRich's Avatar
Default Re: ACG fuse? What does ACG mean? (Chris M)
I am having this problem right now..... how was this resolved? Thanks I know its a complex circuit controlling lotta stuff, but any tips would help me in troubleshooting.
ACG (IG) 15a fuse above fuse puller randomly blows.
Old Apr 3, 2005 | 02:19 PM
Do_Ster's Avatar
ah yes the infamous ACG fuse can give symptons of a bad fuel pump or main relay. i don't know what it stands for either but it's the cause to half of the threads with "car won't start" in the title
Old Aug 27, 2009 | 12:05 PM
pimpster1992's Avatar
New User
my altenator circuit generator fuse keeps blowing out i checked all the wiring from the ecu all the may to the underdash fuse box and couldnt find anything. i unhooked the altenator and cd player and it cranked right up. i hooked the altenaot back up let it run got in the car shut the door and it blew again. i replaced the fuse and unhooked the altenator again and when i turn the key to the on position it blows the fuse everytime. any help
Old Aug 27, 2009 | 07:20 PM
srmofo's Avatar
you got a short in the wire. its time to bust out the multimeter and start tracing that circuit, you can try to isolate the area by having a buddy wiggle the wires, while you keep replacing the fuses or get a fuse saver
Old Nov 1, 2009 | 02:20 PM
unrB18's Avatar
New User
i also have dat same problem w my gsr, it came down to da crankshaft position sensor. ????, wat i did waz put a wire where da fuse go n started da car, yea, i know i can set da car on fire, its a risk i took. after i started da car, i checked which wires got hot, it waz da 2 black/yellow wires comin outta my main relay, so i reved up my car a lil den turned it off, started it again n da wires didnt get hot no more. i den put da fuse back in n it didnt pop but my check eng light came on, i hooked up my scanner n it waz da crankshaft position sensor (ckf). try it out but carefull on not settin ur car on fire tho, good luck
Old Nov 1, 2009 | 05:00 PM
night's Avatar
issa gud thing u went too schu
Old Nov 2, 2009 | 06:23 PM
srmofo's Avatar
wahh? iz 2 hrd 2 tip lik n nglish n stuf
you had a different problem with the same symptom, car wont start. More than one thing can cause that. BTW this thread is almost 6 years old. I think he figured it out by now
Old Nov 7, 2009 | 07:21 PM
HONDUHS LOL's Avatar
New User
LOL WTF IS THIS GUY SERIOUS???? CAN U ****ING SPEAK ENGLISH U DUMB *** HONDUHHHHHHHH DRIVER LOLLLL.....HUUKED ON FONIKS REELE WURKED FUR MEE
Old Jan 31, 2010 | 05:51 PM
accord16's Avatar
New User
Icon3 Re: ACG fuse? What does ACG mean?
i have a 86 accord lx
the car would start and idle on its own for 5 seconds then idles high then shuts off. i put in a new battery and got the alternator tested and it came back it was still good. could the ACG fuse have anything to do with this?
Old Jan 31, 2010 | 06:41 PM
Scott_Tucker's Avatar
If your 86 accord starts and then stalls when it is cold, it most likely needs the carburetor to be rebuilt. Very common. A fuse will not cause this.
Old Jan 31, 2010 | 08:27 PM
accord16's Avatar
New User
the car would start and idle on its own for 5 seconds then idles high then shuts off. i put in a new battery and got the alternator tested and it came back it was still good. could the ACG fuse have anything to do with this? But when it is hooked to the jumper cables to another car it stays running like a champ but once i disconnect the jumpers the idle kickes high then the car dies. im fed up and cant figure out what it is any suggestions?
timeverlastfan
Jun 8, 2015 09:23 PM
Alexcrx
Engine Management and Tuning
Oct 19, 2012 12:31 AM
ej1 assasin
Oct 30, 2006 07:56 AM
tuan...
Aug 7, 2004 05:47 AM
