acceleration lag
Well I have a z6 in my 94 cx hatch and when I accelerate around 1k - 2k the car feels like it lags then after 2.5k it jumps to gain power. Is the reason because I have a cx tranny with the z6 or could there be something else wrong??
i got the same problem but mine works fine till i hit up to 60-65 mph then it starts to lag/bogg/hesitate but then when i push it to full throttle the car runs fine but when i start lifting the accel. it starts bogging out again. Then when i restart my engine my car runs fine till i hit up to 60-65 mph then it does it all over again. Just need a tune? timing off? change a part? help me out.
these are the worst questions, you NEED to post up almost everysingle detail. Even still diagnosis online will be a 10% sucsess rate.
1st, you need to check the timing, then start reading plugs, oil, check TPS voltage, fuel pressure.
Pretty much you need to start swapping thigns out
Jdv_92
Nov 20, 2012 10:10 PM
chrysanderson
25
Nov 1, 2010 09:31 AM
Littlegreend15
Apr 20, 2005 09:02 AM
