AC Issue
Old May 11, 2015 | 03:01 PM
OldSchoolFool's Avatar
Default AC Issue
Today I tried the charge my ac because previous owner had disconnected a line and lost the charge. Well the previous owner also installed an aftermarket condenser fan. Fan doesn't come on when I press the ac switch and neither does the compressor clutch. I power probed the connector to the ac clutch and it does not have power. Fuze under the hood and dash are all good. Any ideas?
Old May 11, 2015 | 03:15 PM
Default Re: AC Issue
Oh and the green light on the ac button does come on when you press it. Not sure if that matters or not.
Old May 11, 2015 | 04:22 PM
v4lu3s's Avatar
RTFM
What are your pressures after you vacuumed and filled?
Old May 11, 2015 | 04:26 PM
Honestly I'm not sure the guy that was helping me stopped once he said that the compressor and the fan should of came on by now but he didn't mention anything about weird or irregular amounts of pressure. Also I went outside about half an hour ago and I jumped the pressure switch and got nothing.
Old May 11, 2015 | 07:29 PM
v4lu3s's Avatar
RTFM
does the ac compressor even turn by hand? how long was it left open? also how long did you hold the vacuum on it?
Old May 12, 2015 | 12:55 AM
slowcivic2k's Avatar
Is this on a 1991 Ford F150? Seriously, how do you expect us to help you? We are not gremlins in your head. Provide specific information, and we will provide a specific answer.
If your compressor does not have 12V at the connector, you have an issue upstream of the connector, in addition to any shenanigans the previous owner, or yourself, have done to the system.
Power probing the compressor 12V connector should energize the compressor coil if it is any good. This will prove my previous information. If it does not energize, you need to examine the clutch ground and the clutch itself for a lack of grounding in addition to anything else.
Old May 12, 2015 | 03:14 AM
It's a 1995 civic with z6 swap and p28 ecu. Like I said I applied power to the compressor and it engaged fine. I held a vacuum on it for half an hour and it staid at negative 25-30 the entire time. I haven't modified the system in and way only the previous owner has installed an aftermarket condenser cooling fan. Basically I just need a check sheet or some sort or and idea or where to start testing things.
Old May 12, 2015 | 02:08 PM
v4lu3s's Avatar
RTFM
download the service manual. should have the factory trouble shooting steps. hit up google for where the downloads can be found for free.
rahu
Apr 30, 2018 10:27 AM
David Guevara
19
Apr 9, 2016 06:44 AM
Single-Cam
16
Feb 10, 2016 07:23 PM
old man honda
Apr 14, 2006 07:01 AM
