AC Fuse keeps blowing?
Old Sep 30, 2010 | 08:21 PM
AnthonyEKPRJ's Avatar
Default AC Fuse keeps blowing?
So my ac compressor fuse blew 3 times yesterday on my EJ7 HX Coupe. Everytime i replaced the fuse it would work great itll blow ice cold then 10 15 mins later itll completely stop the green ac button would turn off no air would come out the vents at all im confused to what it can be anyone have any ideas ?
Old Oct 1, 2010 | 10:35 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: AC Fuse keeps blowing?
rubbed a wire raw sumwhere most likely.
correct fuse used?
any power getting bridged off of it?
Old Oct 2, 2010 | 03:27 PM
fcm's Avatar
fcm
Old Fart
A/C compressor coil is going bad, most likely. 94
Old Oct 2, 2010 | 05:59 PM
im not sure if its being bridged off of its annoying i must i admit/
Old Oct 3, 2010 | 07:23 AM
fcm's Avatar
fcm
Old Fart
Easy to check.
Using an in-line fuse holder, install proper fuse, [same size as the one that keeps blowing]
plug one end into compressor and the other to the batt. if fuse blows replace A/C clutch coil, if not, then start looking elsewhere., what is the MM&Y of car? 94
avinoam83
77
Oct 15, 2018 04:21 PM
NACvicSi
Mar 25, 2007 05:26 PM
Johnnytech
Aug 21, 2004 05:25 PM
bocian
Jun 7, 2002 07:25 AM
