?? about Timing belt pullys??
Old Apr 17, 2005 | 05:38 PM
vtekthis's Avatar
Default ?? about Timing belt pullys??
Im soon converting from a b16 to a b18c, now does the lower timing belt gear the same for the two? and tensioner? So all i need to get different is a b18c timing belt? im using a b16 head.
The reason i ask, is cause, correct me if im wrong the b18a/b are different, so this shouldent affect me?
Thanks Darren
Old Apr 18, 2005 | 05:16 AM
vtekthis's Avatar
Default Re: ?? about Timing belt pullys?? (vtekthis)
anyone?
Old Apr 18, 2005 | 02:01 PM
vtekthis's Avatar
upp for the day
Old Apr 18, 2005 | 04:19 PM
vtekthis's Avatar
anyone ???
Old Apr 19, 2005 | 04:40 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">Im soon converting from a b16 to a b18c, now does the lower timing belt gear the same for the two?</TD></TR></TABLE>I believe the difference is OBD-1 vs. OBD-2 (not B16 vs. B18). If the B18C is new enough to be OBD-2 it has a crank timing sprocket that has the extra teeth for the CKF sensor.
Old Apr 19, 2005 | 07:18 AM
vtekthis's Avatar
can anyone add to this
Old Apr 19, 2005 | 02:23 PM
vtekthis's Avatar
up for a deffinent answer
Old Apr 20, 2005 | 03:08 AM
JimBlake's Avatar
I guess you could check part numbers by calling a dealer?
Old Apr 20, 2005 | 05:23 AM
vtekthis's Avatar
Default Re: ?? about Timing belt pullys?? (JimBlake)
go idea, i figured someone on this board would know right away
Old Apr 20, 2005 | 05:33 AM
JimBlake's Avatar
Well, I KNOW the pulley is different for OBD-2 engines because of the CKF sensor. What I don't know is whether ALL OBD-0 & OBD-1 pulleys are the same.
dem0nk1d
Dec 13, 2007 07:16 AM
Lissav
May 11, 2006 08:09 PM
kobeRy_si
Jun 6, 2005 03:59 AM
