? about ls/vtec, Kinda ?
Old Sep 25, 2003 | 07:56 AM
MysteryWagon's Avatar
Default ? about ls/vtec, Kinda ?
I have 0bd0 B16, and it has a bad distributer. I am purchasing a built ls long block with distributer from a friend the engine is a 94. I know that the LS dissy internals will work in the B16 dissy will I have any problems. like the whole 0bd0/0bd1 thing from the 2 different engines.
this is in a 0bd0 car too.
thanks alot, your answers will be greatly appriciated
Justin
Old Sep 25, 2003 | 08:03 AM
WONG FRIED RICE's Avatar
Default Re: ? about ls/vtec, Kinda ? (MysteryWagon)
first off, are you going to use the LS distributer? or just the internals? or what?
second: if you use the LS dizzy ur gonna have to figure a way to use the obd1 plugs on the dizzy with your obd0 harness.
and last if u are using the internals in the b16 distributer then u won't have any problems... i'm 90% sure of that, but if i'm wrong do correct me.
Old Sep 25, 2003 | 08:13 AM
Default Re: ? about ls/vtec, Kinda ? (JDMB16ACRX)
I want to put the ls internals in the B16 distributer.
I want to do this because my b16 one is bad, and I am getting one with the engine I am buying. So instead of purchasing one I figured, why not switch internals?
Old Sep 25, 2003 | 08:21 AM
in that case, what you are going to do will work. 90% sure Because in the same concept i've used a obd1 dizzy with obd0 internals (from a crx si dizzy internals to a d16y8 obd1 dizzy)
Old Sep 25, 2003 | 08:31 AM
great i will try it, and hopefully that will nock to birds out with one stone
Old Sep 25, 2003 | 09:44 AM
mmuller's Avatar
Mad Scientist
actually, its gonna work, but not good, the obd0 dizzy has different pulses than the obd1
Old Oct 12, 2003 | 12:18 PM
Default Re: ? about ls/vtec, Kinda ? (mmuller)
what is another easy way out then.
itsmebeaner1987
27
Aug 17, 2004 10:48 PM
Race Egr
Apr 28, 2004 01:57 PM
roc
Nov 9, 2003 07:21 AM
straightline
Mar 22, 2003 07:07 AM
