? about extra thick head gaskets
Old Mar 27, 2003 | 03:53 PM
McFly's Avatar
Default ? about extra thick head gaskets
Is there any adverse affects of running an extra thick Cometic head gasket, say 0.078" thick? I have to run that thickness to get my compression ratio back down to 12:1. I am using ARP studs also. Thanks.
Old Mar 27, 2003 | 07:47 PM
McFly's Avatar
Default Re: ? about extra thick head gaskets (UnderFire)
Old Mar 27, 2003 | 08:59 PM
TREVER's Avatar
cam timing changes
Old Mar 28, 2003 | 03:42 PM
McFly's Avatar
Default Re: ? about extra thick head gaskets (TREVER)
Other than cam timing changing, is there any other things to worry about?
Old Mar 28, 2003 | 04:04 PM
poison's Avatar
Valve clearance won't be an issue, cam timing will be changed, and compression will be lowered. Other than that, nothing else will happen.
If you plan on lowering compression and still at a high CR, you will definitely want to make sure there is no detonation problems, otherwise the headgasket will blow much easier being thicker.
Old Mar 28, 2003 | 08:52 PM
delslow94's Avatar
Default Re: ? about extra thick head gaskets (poison)
thicker head gaskets can make hot spots and make your motor more prone to leaks. i would stick with stock and just tune the heck out of it to keep it safer. turbo guys would know about the hot spots with thicker or stacked head gaskets.
Old Mar 29, 2003 | 06:13 AM
riceboy's Avatar
Default Re: ? about extra thick head gaskets (delslow94)
Very ture, thick head gaskets will get hotter easier, but they also dissipate heat easier, if there is not heat being added to the equation of course. The point being that they can hold for daily driving and short bursts, but under heavy constant load, they will build up heat and start to deteriorate, then they will crack, then they will need to be replaced.
Old Mar 29, 2003 | 12:38 PM
intekragsr's Avatar
Default Re: ? about extra thick head gaskets (riceboy)
I thought a thicker cometic headgasket would solve my problem, but then I ended up with a cracked sleeve. Im not blaming it on the headgasket, but for some reason, i like the OEM quality much bettter. The cometic looks cheap to my eyes.
sir.rexington
Apr 25, 2010 04:37 PM
jessevtec
Apr 22, 2005 06:19 PM
94gsr
Jan 17, 2004 02:21 AM
donnjuan2point2
Sep 16, 2003 10:08 AM
NateTEG95
Apr 27, 2003 05:41 PM
