About to do CFK Bypass Trick
im about to do the cfk bypass trick from ff-squad.com to get my car inspected.
My scenario is
99 Civic /w JDM OBD2 GSR with a OBD1 ECU(hondata)
I bought the OBD2a P72 USDM ECU (not installed yet)
I bought the OBD2B-to-OBD2A Jumper Harness for the new ECU (not installed yet)
i bought the stock GSR Injectors (not installed yet)
i bought the Quick Splices
Still need the o2 Simulator
i was wondering after i do the bypass trick and get the inspection....when i go to switch back to my Hondata ECU with my 310cc injectors. Will the Bypass trick effect my original set-up (obd2 engine with obd1 ECU) or will i have to go back some how and unsplice the connections.
Also u do the splices after the jumper harness correct?(where it plugs into the jumper harness from engine not where the harness plugs into the ECU.)
Thanks for any help given
My scenario is
jdmchickx
10
Oct 26, 2011 06:03 PM
MugenSpeclNY
Sep 5, 2011 09:39 AM
halocore
Dec 21, 2008 05:58 PM
tour de france turbo
Aug 20, 2005 06:36 PM
