? about the c-speed compression calculator
Old Sep 22, 2002 | 09:05 AM
Malice's Avatar
New User
Default ? about the c-speed compression calculator
got a question on that compression calculator....
on the bottom where it says piston to deck height...what does that mean? and which one do i choose? my rebuild is gonna be a b18c1 block with a p/p b16 head. im gonna use either a 2 layer or 1 layer gasket. which one should i choose?
Old Sep 22, 2002 | 01:05 PM
Tbone's Avatar
Default Re: ? about the c-speed compression calculator (MaliceGSR)
It means how much in or out of the hole your pistons sit at top dead center. If you set your motor to tdc on a stock motor there will be a certain amount of cylinder volume between the top edge of the piston (not the dome) and your deck surface. So when your making the calculation you need to know how far your pistons are " in the hole" so you can calculate the volume # to add to the equation. It can go the other way also, like on my motor the pistons are at 0 deck which means they dont sit in the hole or out, their flush. (actually after break in and a few dyno runs , their slightly out )
Also to get a accurate reading you will need to know the actual thickness of the 2 layer gasket you will be using.
[Modified by Tbone, 5:08 PM 9/22/2002]
NathanMorris
Jul 28, 2006 05:59 PM
lostone808
Mar 2, 2006 11:26 PM
Takumi Fujiwara
26
Apr 16, 2005 04:22 AM
itr_18
Apr 8, 2004 06:10 AM
MOTOR R
Nov 26, 2001 03:29 PM
