abnormaly stiff clutch (prelude)
Old Dec 5, 2003 | 07:53 PM
2point2's Avatar
Default cable to hydro conversion help!!
I converted my CRX over to hydro clutch - the pedel actually give more leverage then a stock prelude clutch assemble would. You would think the clutch would be very easy to depress but it's actually very hard, even with a stock clutch!! Mechcanically everything is working ok with no leaks but it is freakisly hard to push in the clutch (for stock!) - i'm quite convinced it's a fluid problem but having a CRX i don't know anything about hydraulic clutches.
i used brake lines ran strait off the master to the slave without that diaphram 'thing'. Could this be the problem? Or do i need stiffer lines? I'd like some input from you guys.
thanks.
Modified by 2point2 at 7:21 AM 12/12/2003
Old Dec 12, 2003 | 06:22 AM
2point2's Avatar
Default Re: cable to hydro conversion help!! (2point2)
anyone???
Old Dec 12, 2003 | 09:28 AM
rocketlude's Avatar
I don't think it is in your lines. I think your master cylinder might not be putting enough pressure in the line for you. I have run braided lines to slave cylinders and never run into that problem.
backinblue92
Transmission & Drivetrain
47
Jun 25, 2015 11:01 AM
Chino Chaplin
Mar 12, 2015 09:43 AM
evolvedAP1
Dec 16, 2004 02:02 PM
