99 GSR cluster & neutral safety switch help!!
im back on again ... this time i cant figure it out on my own.
i was hooking up my new quad-pod for my guages. when i was testing wires to see which was switch power n which one was constant i accidentally touched the switch wire on the clock harness with the ground of the clock harness.
it popped the fuse. so i traced it n replaced it. then i went to start my car after everything was done. n the car had problems :
-first i have no power to that switch wire on the clock harness but i do have constant.
-car starts with out having to push in the clutch.
-n last but not least none of the cluster indicator lights or RPM or TEMP guage work...
i need help , at the moment tested all the fuses n they are all good. the dash illumination lights work and the battery indicator light stays on.
hope that summarized it mostly.
need serious help
need serious help
DC5Danny
Mar 22, 2007 08:01 AM
whiteef-8
16
Feb 24, 2005 05:45 AM
