99 converted si problems help
Old Nov 17, 2007 | 04:08 PM
94preludeh22's Avatar
Default 99 converted si problems help
i got a converted 99 dx into an si... it has the b16 a2 motor and trans dc race headers and a shortram intake, it also has a chipped p30 computer obd1 converted harness...... and one 02 sensor
i jus picked this car up not to long ago and it started throwin codes....
it is miss firing like **** and it wont let me rev out past 3600 rpms
does anyone know possiblities of what is wrong
Old Nov 18, 2007 | 08:55 AM
Ryank327's Avatar
Default Re: 99 converted si problems help (94preludeh22)
If the car was a 99 and you have a b16a2 then why did you convert to OBD1. You should just run an Ecu out of a 99 Si (P2T I believe) and use a harness out of a 99-00 Si...
Old Nov 18, 2007 | 02:07 PM
Default Re: 99 converted si problems help (Ryank327)
ask the guy who i bought the car off of... how does that help my problem
Old Nov 18, 2007 | 07:24 PM
Ryank327's Avatar
Get your codes read? If it wasnt throwing the codes when you bought it with the swap then your o2 sensor probably went bad somewhere along the way
Old Nov 18, 2007 | 08:49 PM
dude_123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryank327 &raquo;</TD></TR><TR><TD CLASS="quote">Get your codes read? If it wasnt throwing the codes when you bought it with the swap then your o2 sensor probably went bad somewhere along the way</TD></TR></TABLE>
Chipped computer don't even use the O2 since it's in open loop, and can't use an OBD2 Generic/Factory to read it since the computer is OBD1, but this is what I will definitely do first:
- Check the wires/terminals to the ecu for opens or loose connections
- Then check the soldering on the ecu
- If all that is done, last thing to suspect is the person did not take off "CheckSum" and the ecu is rejecting the program causing it to run on default. ie: can't rev past 3500rpm
Old Nov 19, 2007 | 05:32 PM
Default Re: 99 converted si problems help (dude_123)
yeah i think the ecu needs to be re chipped and tuned.... im takin it to philly dyno works tomorrow to get dyno tuned..... its definetly sensor related... so thats what i tihnk im gonna go do
Brettw
Feb 6, 2014 09:15 AM
zildjianmatt
Feb 11, 2010 07:09 AM
h22rick
Sep 13, 2008 10:27 AM
its WANG yoO
Jun 11, 2007 02:54 PM
ballplayer
17
May 11, 2005 03:45 AM
