99 ACURA CL MISFIRE
Old Nov 21, 2008 | 05:19 PM
restorod's Avatar
Default 99 ACURA CL MISFIRE
I'm getting code P1361 manufacturer control ignition system misfire. This only happens when you first start the car and consistantly under erradic throtle movement when the engine is cold. I can clear the code after the engine warms up and the car runs great untill the next morning when it will do it all over again. Any help? Because my service manual is missing those trobleshooting procedures. 3.0 engine,changed plugs, plug wires, dist. cap.
Old Nov 22, 2008 | 04:16 PM
Evs-One's Avatar
Solbros Owns Me
How many miles?
I've seen a lot of the J30's have too tight of exhaust valve clearance, causing a misfire.
Could be an EGR issue, but wouldn't throw the code in neutral...
Old Nov 22, 2008 | 08:20 PM
restorod's Avatar
Default 99 acura misfire
car has 134,000 miles. the odd thing is it only does it when you first start the car when its cold.
thetake0v3r
Acura TL, RL & ZDX
Sep 9, 2011 03:03 PM
dwm231
Honda CR-V & Element
Aug 27, 2011 01:32 AM
MBlake55
Dec 13, 2010 05:30 PM
LH-93
Sep 7, 2008 04:28 PM
