98 itr axels?
Old Mar 29, 2004 | 09:48 AM
c5_el's Avatar
Default 98 itr axels?
hey i was just wondering if anyone knew if the axels from a jdm 98 itr swap will work with stock EK suspension? i heard from some people that the 98 axels were larger. any help would be appreciated, thanks
chris
Old Mar 29, 2004 | 11:07 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: 98 itr axels? (c5_el)
i do belieeve that the 98+ spec itr axels are too big for the outer hubs i think they are the same as accord splines
Old Mar 29, 2004 | 04:38 PM
c5_el's Avatar
can anyone give me a definate answer? are the splines larger on the 98 spec itr's? how can i make a 98+ itr swap work in my ek civic?
Old Mar 29, 2004 | 05:31 PM
Rusty Shackleford's Avatar
Default Re: (c5_el)
they will not fit. i believe they are 36mm where the civics are 33mm. im not exactly sure on the exact diameter but i know they wont fit.
Old Mar 30, 2004 | 10:19 AM
c5_el's Avatar
so what do u have to do to make them fit? use 96-97 itr axles?
Old Mar 31, 2004 | 05:45 PM
Default Re: (c5_el)
any b-series axles except the 98+ ITR
Old Apr 10, 2004 | 07:36 AM
Slow_Em1's Avatar
Default Re: (Rusty Shackleford)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rusty Shackleford &raquo;</TD></TR><TR><TD CLASS="quote">any b-series axles except the 98+ ITR</TD></TR></TABLE>
or upgrade the hub?...correct?
i need a stronger axel, but i dont want to go aftermarket.
Old Apr 10, 2004 | 11:05 AM
92b16vx's Avatar
Default Re: (Graditude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Graditude &raquo;</TD></TR><TR><TD CLASS="quote">
i need a stronger axel, but i dont want to go aftermarket.</TD></TR></TABLE>
Just use any other B series axle
92+ SiR
93-97 Del SOl vtec
94+ Integra
99-00 Si
You could do a five lug conversion, if you have it, other wise save them for down the road if you plan on doing one, or sell them or trade to someone for the right axle.
Mopedstud
Dec 22, 2009 04:25 PM
