97 civic HB ecu in limp mode and code 16
Old Aug 16, 2009 | 11:45 AM
jams'ej6's Avatar
Default 97 civic HB ecu in limp mode and code 16
My ECU is in limp MODE and code 16 comes up.
my o2 sensor is not working (located on the header)(wires are cut up)
could the o2 sensor be the problem why my ecu is in limp mode?
Old Aug 16, 2009 | 02:08 PM
Former User's Avatar
Default Re: 97 civic HB ecu in limp mode and code 16
Code 16 indicates a problem in the fuel injector circuit. If the resistance and voltage of the injectors is fine, then try swapping in a known good ECU.
Old Aug 16, 2009 | 08:31 PM
jams'ej6's Avatar
ok i'll check asap tomorrow morning thanks
Old Aug 17, 2009 | 03:46 PM
Perfectionist's Avatar
To expand on RonJ@HT's reply, the main relay is a very likely suspect. The code 16 sets if there is a break in the electrical circuit for the injectors.
Old Aug 21, 2009 | 12:42 AM
jams'ej6's Avatar
ok i'll check that out
Old Aug 22, 2009 | 11:56 AM
jams'ej6's Avatar
thanks guys i found out the problem.
project-boosteD
Engine Management and Tuning
May 23, 2010 03:07 PM
JaHnAbOi
Apr 6, 2007 01:20 PM
turborex
Sep 21, 2006 01:07 PM
VeilSide_Mas
Aug 18, 2006 09:24 AM
AGPSuperstar
Sep 14, 2003 04:32 PM
