'93 Teg B16a (JDM) >>>Ecu help! <<<
Old Oct 26, 2004 | 02:59 PM
SiR Inspired ED7's Avatar
Default '93 Teg B16a (JDM) >>>Ecu help! <<<
ok, i just boguht 1993 Integra ls
it has the B16a (JDM) with the A1 tranny
my vtec will not engage because i need a ecu, because the ls ecu is useless
i've heard that the p28 is the correct one, but isn't the p28 for a sohc? i have a Dohc and my friends have told me that i need the p30 which is for my engine...
what else will i need to buy?
plz, help if you can
Old Oct 26, 2004 | 03:06 PM
Katman's Avatar
Default Re: '93 Teg B16a (JDM) >>>Ecu help! <<< (-=*Dusk2Dawn*=-)
ick..you have an LS (A1) tranny on a B16, eh? notta fun setup.
People use P28 ecu's all the time on their B-series VTEC engines, the thing is, they're reprogrammed for DOHC VTEC use. You can technically run a stock P28 on a B16, but its lacking in fuel & timing map department (runs a bit too lean for a B-series engine), hence the reason for reprogramming it.
A P30 is a stock B16A ecu, specifically programmed for a B16 engine. It's possible to P28 reprogrammed with a P30's program (w/disabled knock sensor). Hit me up if you need this service; I reprogram ecu's (see sig link).
crazyguy
Jun 6, 2007 01:49 PM
russianswty
Oct 19, 2006 07:36 PM
MeanGreenEG9
Jul 2, 2004 11:28 PM
E-Rok
Sep 5, 2003 01:07 PM
MeanGreenEG9
Dec 2, 2002 09:59 AM
