92 CX with H22 Swap
Old Sep 6, 2009 | 08:44 PM
00sicain's Avatar
Default 92 CX with H22 Swap
Hey guys maybe someone could give some pointers here.
92 CX with a H22 swap starts and stall right away. Running p13 ECU and throws 2 codes one of I believe is whats not allowing it to run. It throws codes 15 (Ignition output signal) and a code 41 (Oxygen sensor heater circuit). Went thru the entire diag chart and still has the same problem. I have replaced the ignitor and Ohmed the wiring and found that all good. I have tried another ECU (a P05) just to see and it throws the same code again. I am running out of Ideas and any help would be greatly appreciated!
00sicain
Sep 10, 2009 07:20 AM
chas92h22
Dec 31, 2007 05:20 PM
RiCkY vTeC
Sep 16, 2002 12:16 PM
RiCkY vTeC
Sep 16, 2002 06:44 AM
