91 civic no crank
Old Dec 19, 2022 | 08:44 AM
Tooooslow's Avatar
Default 91 civic no crank
I have a 91 civic lx sedan that is B18 and auto to manual swapped. Issue I am having is it will not crank from key just clicks once but always cranks if starter is jumped. I Have changed with new the starter, battery, battery terminals and wires, and all bay grounds as well as ignition switch a which didn't work and lock cylinder was in bad shape so decided to change to the JDI plug and play push to start system and still no change any suggestions would be great thank you
Old Jan 1, 2023 | 11:26 PM
Tooooslow's Avatar
Default Re: 91 civic no crank
Anyone still here?
Old Jan 2, 2023 | 08:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Did you just install the engine and do the transmission conversion or has it been done for some time, used to work just fine, and now doesn't ?
Old Jan 9, 2023 | 03:33 AM
Tooooslow's Avatar
A couple buddies and I did the swap. When swap first completed it ran but had a code for distributor replaced that and it stopped cranking by key
Old Jan 17, 2023 | 09:44 AM
Tooooslow's Avatar
Any ideas?
Old Feb 12, 2023 | 11:40 AM
Tooooslow's Avatar
Brought starter in and tested fine still having issue
Old Feb 12, 2023 | 04:19 PM
Maxcapacity's Avatar
Have you double checked the wiring of the park/neutral safety switch to see if it's still bypassed and those 2 thicker wires are jumped together? Checked fuses? Maybe a bad relay?
Old Feb 13, 2023 | 04:56 AM
Tooooslow's Avatar
Yes the park/neutral safety is connected and all fuses look to be good and main clicks. Thank you for the response
Old Feb 13, 2023 | 04:59 AM
Tooooslow's Avatar
Also it will crank a few times without jumping starter then goes back to a single click after 2 attempts
Old Feb 14, 2023 | 09:52 AM
Tooooslow's Avatar
For park/neutral its the thick I believe black/white wires at the auto shifter location correct? May just go get a bunch of fuses and just replace them all just to be safe since they can appear good and be bad. What relays would all effect this?
OutlawboostedEF
Dec 13, 2014 11:41 PM
daviduhley
Feb 10, 2013 08:33 PM
Subzero318
Apr 12, 2012 01:24 AM
Annihilator
Sep 30, 2011 07:01 AM
