5 lugs hub on DA knuckles?
Is it possible to install a 5 lugs hub from ITR on DA knuckle?
ITR knuckle had to much positive camber on EF, and DA are perfect.
If not possible to use the 5 lug Hub on DA knuckle is it possible on DC 4 lugs knuckle?
Munkyw3rkz.webs.com
yes its possible there is a trend where it was spoken..if i recall you have to press it onto a DA arm basically DA arm with ITR hubs...looks good too.....
TEG92
eg6ajk
TEG92
eg6ajk
Copied and pasted from http://battlecat.8m.com/ITR%20...A.htm
"To complete the rear setup, all you will need is the complete ITR rear trailing arms. . By complete I mean, both trailing arms, calipers, rotors, brake lines if available, and wheels. You can use the DA brake lines. You can also use the DA upper arms, or the ITR set. They are indentical. The choice of rear lower control arms will depend on what style of rear suspension you are using. JDM style rear shocks utilize a drop in style mounting, so JDM DA rear LCA's will be needed. You can use the ITR set, but the geometry is somewhat different. If you are going to stay with stock DA style rear suspension, then use your stock rear lower control arms."
I want to do this to ed6 hatch. It has DA brakes f/r. Can you put itr rear hubs and rotors on a DA trailing arm?
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 »</TD></TR><TR><TD CLASS="quote">http://battlecat.8m.com/ITR%20...A.htm</TD></TR></TABLE>
i rememebr that site but couldnt remember where it was....very informative
thevtecnician
Sep 6, 2006 10:56 PM
