4wd civic???
Old Jan 9, 2003 | 07:10 PM
integra6650's Avatar
Default 4wd civic???
why hasnt anyone ever tried this not to sound stupid
the crv has 4wd does it not so b20 vtec with crv transfer case and rear
custom rear suspension custom driveshafts maybe a fuel cell instead of the tank
might also need to widen exhaust channel strait back
$$$$ but i see this as somewhat possible
Old Jan 9, 2003 | 09:26 PM
NC-B17A's Avatar
Default Re: 4wd civic??? (integra6650)
There already is a 4wd Civic. The Civic Wagovan comes 4wd factory from Honda.
Old Jan 9, 2003 | 09:37 PM
SuperSH's Avatar
Default Re: 4wd civic??? (NC-B17A)
Ya back in 1985 and it was attached to a 1.5l 3-speed. Sounds like fun to me.
Old Jan 10, 2003 | 12:27 AM
scottie1134's Avatar
Default Re: 4wd civic??? (SuperSH)
The 88-91 civic wagons came with in an optional 4wd. It was the d16a6. Yes, the same engine in the si of that gen in the u.s. If you got the manual it was a 6 speed. The auto was a 4speed + O.D. electronically controlled. They are fun to drive. Especially on wet roads. Not much in the power and butt dyno. The 4wd system eats up quite a bit of power. But if you put on a turbo it should be a fun cheap drive around town economical 5 door that weighs 2600lbs that did the slalom faster then the 4 doors and 3 doors and the 4 door is actually longer than the wagon. In other words, Don't Dis the wagon.
Peace,
Scottie
Old Jan 10, 2003 | 05:21 AM
Default Re: 4wd civic??? (scottie1134)
how much did it cost this crazy italian kid
i have too much spent on my car to up and sell it for a talon
just questioning this im not sure how serious i am
Old Jan 10, 2003 | 06:20 AM
jweller's Avatar
CRV AWD system is a 90/10 split, not worth the weight penalty IMO. If you can figure out how to get a 50/50 or 60/40 distribution then go for it. Also you are talking about totally custom rear axles. go look at 4WD CRV rear axles, they look like toothpicks.
the older civic 4WD transfer case is too weak to support much power. somebody (don't ask, I have no idea who at this point) built a drag version and had a lot of problems with exploding transfer cases, and eventually gave up on it.
Old Jan 10, 2003 | 06:57 AM
Default Re: 4wd civic??? (jweller)
since id have to do a custom rear and axels anyway i dont see why ide use a honda rear mayby a dsm rear or something like that
Old Jan 10, 2003 | 08:18 PM
vtecandy's Avatar
there's a couple 4wd trubo civic out there made by honda in japan. none of them have been exported to anywhere else. they are specificely made for a place in japan which is nearly snowing all year. im not sure what year they are though...... anyone can tell me?
Old Jan 10, 2003 | 08:36 PM
sparq's Avatar
Default Re: 4wd civic??? (vtecandy)
UHhhh, you have too much spent on it to sell it for a Talon - but yet you want to go spend $10,000 more to make it have a weak as crap AWD system? Explain that logic to me?
Old Jan 10, 2003 | 09:27 PM
Default Re: 4wd civic??? (sparq)
the time ive put into the civic. i was just pondering this idea dont take me seriously
Old Jan 10, 2003 | 11:25 PM
Kamin's Avatar
not worth the time and effort
even if you got the CRV's system working
its still FWD setup with RWD assistance.
not a full AWD setup.
Erwill22
Mar 31, 2019 12:14 AM
andrew.anderson
Sep 27, 2005 11:19 PM
Lynxen
Feb 28, 2005 08:31 PM
nightryder21
Jun 18, 2003 11:13 AM
