4 wire o2 wiring?
green wire goes to any green/wht wire on your harness other than map.. so tps, watertemp etc.. or **T** to D22 on ecu.. (make sure it's still connected to the harness from the ecu.. but splice your wire into it as well)
white wire goes to your old single wire o2 wire.. or D14 on ecu
one black goes to yel/blk injector wire.. or **T** to A25 on ecu.. (make sure it's still connected to the harness from the ecu.. but splice your wire into it as well)
the other black goes to A6 on the ecu.. you may need to add a pin.. but this is a must for 4wire o2
the black wires are supposedly indistinguishable from eachother.. just needs to complete the circuit either way, so doesnt matter which one goes to which.. just pick one
--truent
--truent
AdamITR
May 14, 2003 05:44 PM
KevronsEG
Mar 31, 2003 10:11 AM
