4.7 final drive question
Old Jun 29, 2006 | 04:49 PM
gsrbubble93's Avatar
Default 4.7 final drive question
wussup guys i just put a 4.7 final in my stock 95 gsr trans and i was wondering if if im crusing on the highway in 5th at say 60 mph should my rpms be higher then they would have been with the stock 4.4 final or is that only if u change gears also because it seems basically the same as before i installed the 4.7 any info would help thanks guys
Modified by gsrbubble93 at 7:57 PM 6/29/2006
Old Jun 29, 2006 | 06:57 PM
Default Re: 4.7 final drive question (gsrbubble93)
bumpppppp
Old Aug 14, 2006 | 08:58 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
all your rpms are gonna be slightly higher. if they are indeed the same, you didn't install a 4.78. it's not that big of a diff, btw.
Old Aug 14, 2006 | 10:04 AM
Bense's Avatar
Default Re: 4.7 final drive question (not so civic)
gsr trans = 3000rpm @ 60mph
gsr trans w/ 4.785 final drive = 3250 @ 60mph
boostontheD
May 1, 2012 11:41 PM
FoShizzle
Sep 8, 2007 03:10 AM
L8ApexH22
Jun 29, 2005 07:49 AM
4DooRGiSzer
Nov 11, 2003 08:22 PM
