3rd gear poping out of gear
Old May 31, 2006 | 08:40 PM
systemoverload's Avatar
Default 3rd gear poping out of gear
3rd geat pops out while driving could it be the clutch or Syncro or combination of both? curious before i spend more money then i have too
Thnka in advance
Old May 31, 2006 | 08:51 PM
Default Re: 3rd gear poping out of gear (systemoverload)
N/m i stoped being lazy and searched
thanks any ways
Old Jun 2, 2006 | 08:44 PM
vtec fan's Avatar
bad Syncro in the tranny.
Old Jun 2, 2006 | 08:56 PM
kusyurdaddy's Avatar
u would have to replace the 2nd and 3rd gear set. cost about 300 or so from the dealer.
Old Jun 2, 2006 | 10:09 PM
Flexmyrex's Avatar
before anything you need to check the shift linkage/cables for damage(bent, cracked), adjustment. check the shifter to make sure there is no physical interference. Broken trans/ engine mounts can also cause this.
As for internal problems it could be worn detent springs, bent shift rod or fork, too much input shaft endplay, worn syncronizer, worn dog teeth on the gear or synchro.
Old Jun 2, 2006 | 10:50 PM
HossRacingF22B1T's Avatar
i had the same problem but in 5th gear, my tranny oil was low. after adding oil everything was fine. try checking your tranny oil.
CubbyChowder
Jun 1, 2010 04:44 PM
92civiceg9gsr
Transmission & Drivetrain
Feb 6, 2009 08:53 PM
.paul
Jan 12, 2007 12:35 PM
AznInvasion
Aug 24, 2002 06:15 AM
TypeSH
Jun 9, 2002 12:00 PM
