.25mm overbore CTR pistons in b18a/b
Old Jun 8, 2002 | 01:29 PM
BR's Avatar
BR
Default .25mm overbore CTR pistons in b18a/b
I have heard some unnerving stuff about running the CTR pistons in the b18a/b motor. Something about inconsistant compression and clearance issues.
Has anyone here had any experience with this setup?? I am going to be running them in my LS and I want to know if I am going to have problems with them.
I am not going to be milling my head so the clearances and everything will be normal. The 11.45:1 compression ratio just from the pistons will be enough for me.
I would really appreciate it if someone could help me out with this little dilemma that I am having.
Later,
BR
Old Jun 8, 2002 | 01:37 PM
GSpeedR's Avatar
Default Re: .25mm overbore CTR pistons in b18a/b (BR)
Hey BR,
I think that there is a good chance of clearance issues being that the CTR pistons have a higher dome than regular B18 pistons. However, I'm sure you've considered that already.
BTW are you going to use your B18 rods or different ones?
Old Jun 8, 2002 | 01:53 PM
BR's Avatar
BR
Default Re: .25mm overbore CTR pistons in b18a/b (GSpeedR)
I have thought about the clearance issues, but with a proper valve adjustment there is no reason that they should collide in any way unless the timing belt breaks or slips.
I will be using stock b18a/b shotpeened rods.
I was told that the angle of the valves to the PCT pistons in an LS would cause a wavering, inconsistant compression ratio...
2ToneEM1
Feb 26, 2008 04:10 PM
itr1244
Jun 7, 2006 10:55 AM
RenzoDaPlayboi
Nov 22, 2005 08:33 AM
wickedEFguy
Jan 21, 2003 03:14 PM
BR
Aug 21, 2002 11:31 AM
