2000 Civic Si Timing Belt
Old May 16, 2004 | 02:03 AM
2000CivicSiLasVegas's Avatar
Default 2000 Civic Si Timing Belt
I'm approaching 60k miles and the dealer says I should replace the timing belt. He says that living in Las Vegas (high temperatures), can cause them to fail sooner.
Does this sound right?
Should/could I wait longer?
How much should a dealer charge?
thanks
Old May 16, 2004 | 10:48 AM
turbo96wr's Avatar
Default Re: 2000 Civic Si Timing Belt (2000CivicSiLasVegas)
check with another dealer becuase it used to be 60 and honda moved up to 90 now.but if you run hard and you have the money switch it now plus the water pump, and i also would change the front main seal all done at the same time.....
MonkeyPuzzle
Dec 30, 2013 04:04 PM
honda2000vp
15
Oct 11, 2010 09:39 AM
silvercivicsir
Jun 21, 2008 12:58 PM
EM-One
Jun 7, 2007 09:34 AM
2000CivicSiLasVegas
May 17, 2004 09:34 PM
